March 9, 2022 at 4:24 pm
yeico01
SubscriberHi everybody,
I am doing a simulation in ansys CFX of aexternal gear pump. I have problems that I want to evaluate the outlet pressure by changing the angular speed in RPM but there is an erroneous variation of the outlet pressure, since when increasing the angular speed the pressure must increase and the results show the opposite.
I have changed the time steps but I have the same result.
Do you know what the problem would be?
thanks
March 17, 2022 at 11:43 pmSurya Deb
Ansys EmployeeHello,
Check the pressure again for the 2870 RPM case. Do you get the 14 psi as area averaged pressure value at the outlet?
Regards SD
2630
2104
1327
1110
461
