February 22, 2022 at 2:32 pm
mohammedlaminemekhalfia
SubscriberDear ANSYS community.
Hope that this will find you all well.
As I am a Ph.D. student, I would like to perform as part of a new innovative idea to simulate a Magnetoresistive sensor. I am a beginner with ANSYS maxwell as through web search I guess it is the tool for sensor's simulation.
I tried to look for some useful users guides or videos about similar examples but I could not find anything.
so if there is among you who performed this type of simulation I would highly appreciate your help and guidance.
February 23, 2022 at 12:17 pmNavya C
Ansys EmployeeHi @Mohammedlamine The setup and analysis would be the same as the other examples you find in Maxwell to study the Electromagnetic effects.
You can take a look at the below getting started guide to get an understanding.
You can also look at the inbuilt Hallsensor example in maxwell under File>open examples>Maaxwell>Sensors
Regards Navya
- Maxwell, HFSS or Q3D?
- Error
2524
2066
1279
1096
459
