Simulation not running on my machine
    • SaiD
      Simulation is running fine on other machine with same specs as mine, but it does not move forward on my machine. Why is this happening?n
    • Daniel Shaw
      You should check the available space on your local C: drive. If the project archive (.wbpz file) is transferred from another system, it is temporarily stored on your local C: drive. Problems will occur, if the project archive is too large to store on the local C: drive.n
