October 30, 2018 at 7:09 am
snr1
SubscriberHi sir, i am trying to simulate the 3D turbulent pipe flow. But i am not getting the values as mentioned in the existing literature/Cornell 2D turbulent flow. Can you help me how to do the complete analysis and post processing.
October 30, 2018 at 8:00 am
Keyur Kanade
Ansys EmployeeHi,
Can you please describe your issue in detail? Insert some images.
Best practices to fully leverage the ANSYS Academic Community:
Be efficient - As our community grows it is becoming more likely that you are not the first to ask this question. Please search before creating a new post.
Be clear - Provide supporting screenshots, error messages, and background information. No simulation files will be opened by ANSYS support engineers.
Be precise - Please use the right tags to help our engineers find your question.
Be patient - Please allow three days for someone to get back to you, if you have an urgent question, please email your ANSYS Account Manager.
Be helpful - Please help our community grow by answering other's questions and telling your academic colleagues about this resource.
Keyur
October 30, 2018 at 8:28 am
snr1
The images are attached above. As we can see, the center line velocity has to increase from starting point to ending point. But here the trend is opposite. And nature of curve is also not smooth. Its wavy nature. How to get accurate center line profile? i am using 2 equation model with enhanced wall treatment . Geometry dia 0.2m ,length 8m and Re of 10000. Can anyone help me?
October 30, 2018 at 8:38 am
DrAmine
Ansys EmployeeThe curve will depend on your mesh topology. Try to use a line with 1000 samples. Moreover have you heard about max. velocity overshoot? Please look for that.
By the way go through the BPG shared by Keyur and add more detailed screenshot where one can judge the quality of the grid.
October 30, 2018 at 9:49 am
seeta gunti
Ansys EmployeeAdding to Keyur and Amine, You are modeling turbulent flow in a pipe with two equation models and plotting the center line velocity along x-axis right! If the flow is fully turbulent, your velocity magnitude at the centerline should be more or less uniform since at the center, flow is fully developed. You can check the velocity profiles in a pipe ( search in google) If you are modeling the developing region, then it will increase from starting and reach to certain mean velocity and remains constant.
If you are plotting the boundary layer velocity, it will increase from starting to ending. Please check the reference paper what they are referring.
Thanks,
Seeta
October 30, 2018 at 10:04 am
Keyur Kanade
Ansys EmployeePlease cross check all inputs as given in tutorial.
Make sure you have a good mesh before proceeding to solver.
Make sure that solution is converged.
Keyur
October 30, 2018 at 3:36 pm
October 31, 2018 at 2:48 am
Keyur Kanade
Ansys EmployeeLooking at mesh, it looks like you have created very fine boundary layer prisms.
With this you may need to use k-e realizable enhanced wall treatment for turbulence.
Please check the mesh settings given in tutorial. Then use appropriate turbulence model.
Keyur
November 1, 2018 at 11:26 am
seeta gunti
Ansys EmployeeBy seeing the mesh image, As keyur mentioned, you have used very fine BL but the aspect ratio is looks higher. Can you refine near the center of the pipe . Since it is a simple pipe, you can create a nice hex mesh.
Seeta
November 2, 2018 at 12:22 am
mcoderon
Ansys EmployeeHi,
As Seeta suggested you can generate a hex mesh. You could use the "sweep method" for that since you have a simple pipe (See the Meshing User Guide).
Check that your mass balance is verified at the inlet and at the outlet. If not your solution may not be converged, if that so you may want to double check your boundary conditions. (Do you expect a negative velocity?)
Since you have a refinement for the inflation layer follow Keyur's suggestion about using a different turbulence model. The k-omega SST is a valid option too. However make sure that your grid satisfies the condition of having a y+ = 1.
Best Regards,
Marco
November 2, 2018 at 3:37 am
snr1
SubscriberDear Marco, how to create hex mesh? and how to use sweep method? how to calculate y+ value? as because i am new to fluent. Please help me. Greatly appreciated for your help
November 2, 2018 at 5:57 am
Keyur Kanade
Ansys EmployeePlease have look at 3 part video for hex meshing.
November 9, 2018 at 4:14 am
snr1
SubscriberThe problem is that, in post processingi have drawn lines at different location for finding the velocity profile. For example, at outlet cross section, i have drawn line as shown in below.
As we can see, the line is crossing the diameter of circle. Though, its original diameter is 0.2 m. That we can check from the scale, that as shwon in below fig.
Why the line drawn in post processing is crossing the circle, though i have drawn with actual dimension like diameter 0.2 m. Also i am not getting any plot date on this line. Its showing empty plot. How to resovle this issue?
November 9, 2018 at 5:38 am
DrAmine
Ansys EmployeeChoose the option cut at first to see it the cut will be detected. Other option will be through intersection of plane with a boundary.
November 9, 2018 at 5:51 am
snr1
Subscriberthank you Amine, can you suggest me the some papers regarding turbulent flow through 3D pipe flow?
Materials regarding turbulent models and some modifications in that models
Let me know the possible meshing options for 3D cylindrical pipe
Thank you
November 9, 2018 at 6:35 am
DrAmine
Ansys EmployeeIt would be meaningless if one create a non structures O-grid mesh for a simple geometry like a pipe. Go for that. Regarding papers and books start looking in Pope' s turbulent flow book and BPG from Florian Manger. -
November 9, 2018 at 6:40 am
snr1
SubscriberDear amine, i am doing meshing in fluent itself. I am not doing in ICEM.
November 9, 2018 at 8:47 am
DrAmine
Ansys EmployeeThen native poly with inflation layers: Yplus= 1 / 15-20 Cells in the Boundary layer for Low-Re approach.
November 9, 2018 at 8:57 am
snr1
SubscriberDear amine, what you are trying to say? i didnt understand.
November 9, 2018 at 10:20 am
DrAmine
Ansys Employee1/Yplus =1-5
2/15-20 Cells in the boundary layers
in order to have a high quality Low-Re mesh.
November 10, 2018 at 12:04 pm
Ayodele
SubscriberHello everyone,
I am studying air flow through a rectangular duct. I wish to confirm if I can use ratio of 1.2 for my mesh independence study to generate the fine and finer meshes from the initial coarse mesh.
Thanks a ton for your responses.
Ay.
November 12, 2018 at 7:17 am
Keyur Kanade
Ansys EmployeePlease use 1.1 to 1.2 ratio. It would be ok.
November 13, 2018 at 4:22 am
Ayodele
SubscriberThank you kkanade.
I also observed that my Continuity and epsilon solutions aren't converging below e-03. I just attempted to run the simulation longer (about 1800 iterations) but not dropping to e-04 still. Any suggestions?
Thanks I advance.
Ay.
November 13, 2018 at 5:54 am
DrAmine
Ansys EmployeeScreenshot of solution methods please. -
November 14, 2018 at 8:05 am
snr1
SubscriberHow to find the heat transfer coefficient in fluent 18.1?
November 14, 2018 at 9:18 am
DrAmine
Ansys EmployeeFluent has a good documentation where you might find almost everything within a couple of trials.
Under Wall Fluxes you can find the HTC's: Surface HTC and Wall Func. HTC.
November 14, 2018 at 11:31 am
November 14, 2018 at 11:43 am
DrAmine
Ansys EmployeeRun double precision, coupled with pseudo-transient option and you might change Pressre interpolation to PRESTO! or Body-Force-Weighted (not really relevant)
November 14, 2018 at 9:51 pm
Ayodele
SubscriberHello Abenhadj,
Thanks for your response. Kindly confirm I can use the pseudo-transient option for steady flow simulation. Not sure what the pseudo-transient mean?
Secondly, do you mean there is no need to change Pressure interpolation to PRESTO! or Body-Force-Weighted?
Thank you for your time.
Ay.
November 15, 2018 at 3:45 am
snr1
SubscriberBut fluent is giving wrong values. How to find exactly?
November 15, 2018 at 6:28 am
DrAmine
Ansys EmployeeThis is not efficient anymore. Please create your own tgread with your question.
For coupled steaty state solver there is an option in the solution page named pseudo time stepping. The pressure interpolation is not s must at first and please start going through all standard tutorials to get familiar with the software you are using.
2524
2066
1279
1096
457
