March 8, 2021 at 2:44 pm
ayodele1
SubscriberDear ANSYS,nI am simulating flow of an hot fluid at 192.7C from a tank to a valve, at the upstream side of a pump. No mixing of flows is involved, rather the hot fluid flows from the tank (@ 3.21 barg header pressure) to the valve. I am setting up the flow physics in FLUENT, but unsure about what parameter of the flow to use as surface monitor.nShould I use wall shear stress, or flow rate?nThanks in anticipation.nAyodele1 n -
March 8, 2021 at 3:37 pm
YasserSelima
SubscriberIf the level of the fluid in the tank decreases, neither of these monitors will reach steady state. nWhat do you want to get from the simulation? This is what will determine your monitorsn -
March 8, 2021 at 9:29 pm
ayodele1
SubscriberI am actually trying to compare flow parameters at some points in 2 pipe configurations, which are parallel to each other, one closer to the tank and the other further away from the same tank. I plan to simulate the flow independently and obtain suitable flow parameters at the points of interest.nThank you.nAyodele1 n n -
March 8, 2021 at 9:40 pm
ayodele1
SubscriberI am setting the inlet with Pressure inlet boundary condition, and the outlet with Pressure outlet boundary condition. I have applied the pressure in the tank as the pressure inlet value, and 0 barg applied on the outlet.nThank you.nAyodele1 n -
March 8, 2021 at 10:03 pm
YasserSelima
SubscriberSo, if you are interested in the velocity, use it as monitorn
Viewing 4 reply threads
Trending discussions
Top Contributors
2630
2110
1335
1110
461
Top Rated Tags
