July 24, 2018 at 5:53 pm
pratsat1
SubscriberHey guys, I've been trying to build a bubble surface with ions attached to it, but the bodies keep getting unified into one body. Id there way to separate them? The bodies are spheres of one size, in contact with a larger sphere and with at least three other spheres at the same time. The error it's giving me is the non-manifold geometry error, so how do I make it manifold geometry?
July 24, 2018 at 7:58 pm
July 25, 2018 at 11:05 am
Ansys EmployeeNon manifold is often flagged where you have objects contacting at a point or thin edge. You probably need to overlap the spheres slightly, and then do some geometry manipulation to form the connections.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1349
1118
461
