LS Dyna
LS Dyna
Topics relate to LS-DYNA, Autodyn, Explicit STR and more
Simulation of Compression Test of Thermoplastic Material
    • AMOLGILORKAR
      Dear friends,
      I have performed a compression test and I have all the data. Now I want to validate the experimental data using simulation results. Three specimen were tested with displacement rate of 0.25 mm/s, 0.5 mm/s and 0.75 mm/s individually.
      Should I use Explicit Dynamics or static structural analysis?
      Material used is ASA (thermoplastic), which is not listed in ANSYS materials data. I want the stress strain curve upto 50% strain, which is in the plastic region (from experimental data).
      Hence my question is should I use only isotropic data?
      Please reply.
    • Ram Gopisetti
      Compression test are mostly made using the implicit so preferably use Static structural with sub steps on.
      yes you can use isotropic data. Check the following research papers to know more on the approach on implementing the material model.
      Cheers, Ram
    • AMOLGILORKAR
      Thank you Ram for your reply. In experiment
      this is the True Stress-True Strain plot. So if I use only isotropic properties, then I am getting curve upto elastic region.
      I have gone through this paper for material properties. Also I have the material properties data provided by manufacturer of ASA material, hence I used that data only.
      Please find the below image showing the material added using the material properties provided by manufacturer of ASA material.
      Please suggest some additional properties needs to be added to get the approx curve. Thank you.
    • peteroznewman
      Hi I helped a member in this site with this kind of a structure before, and because of the self contact, found Explicit Dynamics to be very beneficial.
      Unfortunately, the link to the original post is broken.
    • AMOLGILORKAR
      Thank you @peteroznewman for your reply.
      Material (ASA) used for fabrication is not listed in Ansys Engineering Data Sources. Hence can you please suggest some additional properties needs to be added except this.
    • szeles1996
      can you tell us how you did that simulation?
      I would really appreciate if you could briefly explain the workflow, constrains etc.
    • Ram Gopisetti
      its suprising that the trends of the cure is same with some offset, Have you tried mesh convergence studies, what is the strain rate of your experiment, perhaps the following paper might help you on tuning the material properties
      Finite element analysis of 3D-Printed Acrylonitrile Styrene Acrylate (ASA) with Ultrasonic material characterization by Yee Ling YapÔêù, William TohÔÇá, Rahul Koneru and Zhong Yang Chua
      cheers, Ram
    • David2020FEM
      I am simulating lattice structure using explicit LS _DYNA with ANSYS workbench. I do have compression test data and wanna use it in ANSYS, so I need suggestions on how to input stress vs strain experiment data into ANSYS? Also wanna see both elastic and plastic regions on the curve after simulation, is it possible?
      In another word, I wanna validate the experimental result with the simulation. Hence could you also share with me the above video procedure for the simulation of lattice compression?
      Thank you very much! Appreciated!!
      • Raghu Nandhan
        Please help with settings for compression testing on lattice structure with 1mm/sec loading
Viewing 7 reply threads
