simulation of compression test performed on UTM
    • parimalpatil0369
      Have performed compression test on the hollow mild steel tubes of different shapes like circular, square and rectangular. Need to simulate the same with strain rates or the die travel speed. the outcomes may be comparable to the shapes or deformations which I have attached here with please help me with this Sir.
    • peteroznewman
      Why do you want to simulate the compression test?nWhat output do you want from the simulation?nWhat material properties do you have for the steel?nHow are the tubes connected?n
