Optical
Optical
Simulation of germicide lamp
    • Xime54
      Hi everybody,
      ANSYS made a simulation of a germicide lamp (PHILIPS TUV30W, UVC) and give us the model in the library. I have 2 questions about this:
      1) They used a "bandpass filter": what is a band pass fgilter in ANSYS SPEOS, how to put it in the model, and does anyone understand why they use it? Is it used because the flux is givent in [200-280nm]?
      2) I guess that UVC are quickly absorbed by air. Does anyone know the absorption coefficient, to re-create an "air material" which really absorbs UVC?
      Thanks a lot.
      Maxime
    • Ashish Khemka
      Please see if the following link helps:
      Designing UV Light Disinfection Systems | Ansys Webinar
      Ashish Khemka
    • Xime54
      Thank you very much Ashish, this was EXCACTLY what I needed  💪🙏👍
      Maxime
