Simulation of Half impulse radiating antenna
    • Abi
      The feed excitation that must be provided for half impulse radiating antenna (HIRA) is: nFeed arm 1: positive excitation voltagenFeed arm 2: negative excitation voltagenReflector & Ground plane: neutral (0 V)nHow to provide the above-mentioned excitation to HIRA under driven terminal and transient solution type?n
    • rtk
      ,nCould you please elaborate your simulation needs, and share some screenshots of your geometry and port setups?nFYI: Please embed the images directly in to your post rather than using attachments.nnBest Regards,n
    • AndyJP
      and the solver mode you are trying, because it is meaningless in DrivenModal, I guess. n
    • rtk
      , nIt seems like Abi is talking about DrivenTerminal and Transient solution type.nAnd yes, you are right!.. If it is DrivenModal the way he wants to get the antenna excited is pointless. Regards,n
Viewing 3 reply threads
