March 6, 2019 at 5:44 am
snr1
SubscriberI am trying to create a structured mesh for a helical coil in ICEM CFD. But I was not succeeded. Later I shifted to unstructured mesh generation in a workbench. While doing so, I have created inflation layers with first layer thickness. But inflation is not created and it shows "Hard edges are not supported and may be ignored for pre-inflation, please check your model carefully." How to resolve it? Is it possible to generate a structured mesh for a helical coil in ICEM CFD? if so, can anybody help me? -
March 6, 2019 at 6:07 am
Keyur Kanade
Ansys Employeeas ansys employees we can not download attachments. can you please insert some zoomed in images of your geometry.
in general, icem can be used for hex mesh in helical geometry.
for your geometry, go to dm, then use tools - repair - hard edges. then go to meshing and create tet mesh with inflation.
if this helps you, please mark this post as 'is solution' to help others on forum.
March 6, 2019 at 6:22 am
March 6, 2019 at 10:19 am
Ansys EmployeeIf you sweep the body in Workbench (ANSYS) Meshing does it work? That'll give you an unstructured hex mesh, and you can inflate it too. Probably easier than trying to block the body manually in ICEM CFD.
March 6, 2019 at 10:43 am
snr1
SubscriberTq sir, but for hexa mesh, inflation is not working. I created geometry in SolidWorks and imported into a workbench. Can you suggest any alternative?
March 6, 2019 at 12:00 pm
Ansys EmployeeSet the body mesh to sweep and set a manual source. Then inflate the sweep method (right click on the tree entry): sweep inflation is applied to the source face from the edge(s).
March 6, 2019 at 12:15 pm
snr1
SubscriberTq sir, i will try it and let you know the result. How to control number of layers in this method with required y+ value?
March 6, 2019 at 1:17 pm
Ansys EmployeeSame as any inflation method: it's just applied slightly differently.
March 7, 2019 at 2:39 am
Keyur Kanade
Ansys Employeefor such geometry, sweep may not work in one go.
you may need to split the geometry in few bodies.
e.g. split 360 degree into 4 bodies of 90 degrees.
then use sweep method.
March 7, 2019 at 5:42 am
snr1
SubscriberWhat is the best and simple method to generate a mesh for the above helical coil?
March 7, 2019 at 11:46 am
Ansys EmployeeI'd sweep it.
March 7, 2019 at 12:23 pm
snr1
March 9, 2019 at 8:21 am
snr1
SubscriberCan anybody suggest, What is the best and simple method to generate a mesh for the above helical coil?
March 11, 2019 at 3:27 am
Keyur Kanade
Ansys Employeethis is already mentioned by rob and me. you will need to use sweep method.
March 11, 2019 at 5:12 am
snr1
SubscriberOkay tq sir for your reply
March 11, 2019 at 10:36 am
snr1
SubscriberBut the problem is inflation option is not working once we sweep the mesh. But i want to make inflation layers to capture the near wall effects. So, how to proceed further?
March 11, 2019 at 11:11 am
Ansys EmployeeInflation for sweep is set slightly differently.
Set up the mesh method for the zone as Sweep and set a manual source face (one end of the coil).
Once the sweep method is set, right click on the sweep method in the tree & inflate this method.
Apply the inflation to the end face & perimeter edge.
You may need to adjust the number of layers & cell size as it's quite a small diameter so inflation may give a poor mesh if you don't get the sizing right. You're also aiming for an aspect ratio of 1-2 up the tube to get the VOF interface correct: you may find the cell count is very high so may need to reduce the length of the coil.
March 11, 2019 at 11:25 am
snr1
Subscribernice the sweep method is set, right click on the sweep method in the tree & inflate this method. Apply the inflation to the end face & perimeter edge.
I didn't understand this. If your mind can elaborate clearly
thanks for your patience.
March 11, 2019 at 4:30 pm
Ansys EmployeeWatch this video from about 4:40
March 12, 2019 at 4:19 am
snr1
SubscriberTq sir, i got it
March 13, 2019 at 5:44 am
Keyur Kanade
Ansys Employeeif this helped you, can you mark this as 'is solution' to help others on forum.
March 13, 2019 at 7:00 am
snr1
SubscriberTq sir, I was able to develop good mesh by using sweep method. Greatly appreciated for your help
March 15, 2019 at 4:34 pm
snr1
SubscriberDear sir, if I run without UDF, it results floating point exception error and temperature limited in 20 cells of zone1. How to resolve these issues?
Actually, I am simulating the water evaporation process in the helical coil. The boundary conditions are
inlet: water (100%) with mass flow rate inlet and temperature (370K)
wall: constant temperature (500K)
outlet: outflow
operating conditions: 101325 Pa and 300K
saturation temperature in the evaporation and condensation model: 373K with 0.1 frequency.
model: VOF implicit with implicit body force
March 15, 2019 at 4:49 pm
Ansys EmployeeLet's keep the mesh here & solver stuff here https://forum.ansys.com/forums/topic/mpi-error/ so I'll move the last post & lock.
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
3744
2573
1821
1236
594
