January 18, 2023 at 4:25 am
Sherin Joseph
SubscriberI build a 600Hz medium frequency transformer in Ansys Maxwell (transient simumation). I woul like to give input from a PWM inverter. So I interconnect transformer with PWM inverter developed in Ansys simplorer.
Since the out put frequency is 600Hz, I have chosen a switching frequency of 24,000Hz (40 times of fundamental frequncy).
I have chosen 2ms as the total stop time and 5micro sec as the step size, when I run the same, I got an error
"Warning 10907 - A complete convergence within the maximum number of iterations allowed of <40> could not be achieved for all time steps. Convergence failed on conserved terminal
. Node: net_2<%> >> Calculate at t=3e-05 s " What is the correct stop time and step size for my simulation for overcoming this warning and for getting correct switching.
January 25, 2023 at 3:44 pm
Deyu Li
Ansys EmployeeThis is a warning about convergence, please refer Simplorer manual for help. Keywords are "TR(Transient) Options", there are serval methods to resolve convergence issue.
- Maxwell, HFSS or Q3D?
- Error
2588
2080
1315
1108
459
