LS Dyna
LS Dyna
Topics relate to LS-DYNA, Autodyn, Explicit STR and more
Simulation of Multiprocess Destruction Processing
    • 庆瑞 张
    • 庆瑞 张
      In addition, a simulation of destruction can be done. Includes simulation of corrosion and weathering as well as vibration, and the degree can be adjusted freely. It's a good idea to have a separate list library with options for changing or even destroying objects, including presses, taps, hammers, drops, shots, and destruction of various weapons, including missiles. Drag in with the mouse and place it in certain positions of the object to animate the simulation. It is suitable for many types of damage simulation, from the fall of various types of objects to the damage simulation of buildings. In the past, there were many funny and funny ring-breaking videos on YouTube, such as a giant hammer, hammering objects, or various hydraulic press crushing items, and various types of shredders, such simulations can be used to design the blades of various types of shredders, as well as the blade strengthening skeleton, knife design. It is not only necessary to simulate the appearance and internal form of the original item after certain damage, as well as the density of the stress state and the change of material, but also to be able to continue the simulation after adding some treatment to the original object. The treatment includes a variety of treatments for various cosmetic processes, as well as the degree of treatment, such as quenching, plating, adding other elemental materials, including structural modifications (this structural change can be re-changed using 3D software) The destruction of different types of buildings, hulls, aircraft, etc. by various types of weapons, aging buildings, and natural erosion of salt spray at sea. Burning and so on and so forth, and so on You can also use multi-type destruction processing multiple times in stages to see the final result.
