Simulation of the electrochemical process of anodization of aluminum
    • nmsheehan
      I am trying to simulate an electrochemical process, the anodization of aluminium, which leaves an array of nanopores on the aluminium surface.
      How would be the best way to go about this using Ansys? Any help or indication in the right direction would be greatly appreciated.
    • Karthik R
      Administrator
      Hello
      You should be able to use ANSYS Fluent for this. Please look at the chemistry models as well as reacting mechanisms on how to set your model up. You might be able to find ideas on how to set this up on YouTube as well.
      Hope this helps.
      Best Karthik
    • creddick
      Hey nmsheehan, had you any luck running the electrochemical module of Fluent? I'm trying to simulate a fairly simple water electrolysis reaction but the simulation doesn't run any reactions even though I believe I have set the reaction up correctly as per the electrochemical section of the user manual. If you got it to work, I'd really appreciate some pointers on how you got it to run. nThanks,nConorn
