September 4, 2019 at 9:46 pm
MohamedAyman1
SubscriberHello!!
I'm trying to simulate the transient behavior of a thermo-electric cooler with a heat sink attached to the hot side to dissipate heat.I have two fluid domains. One is attached to the cold side and the other is an enclosure for the heat sink(see the attached photo).I want to make a coupling between the fluent and thermal-electric modules in WB in order to make a co-simulation since it is a transient simulation and the temperature in the cold and hot side changes with time as well as the convection heat transfer coefficient. I've already done a transient simulation but only with the thermal electric module by adding commands to MAPDL and h on both sides(hot and cold) and it gave a good results but i want to make fluent to calculate the h and to be coupled with the Thermal electric module.(system coupling)
I REALLY need help!!!!
September 5, 2019 at 11:53 am
September 5, 2019 at 12:04 pm
SubscriberMohamed, please wait to click the Is Solution link below a post until you have actually solved your problem.
Open the ANSYS Help, click the Home button and search for Load Transfer Coupled Physics. You can read Chapter 3.
2066
1279
1096
457
