June 27, 2022 at 5:39 am
itsme_tilak
SubscriberToday I encountered a different problem while trying to perform CFD on a simple water wheel. The water wheel is rotating at a specific angular speed and requires vertical positions of the turbine blade at any given position. I have activated both frame and mesh motion but the result is completely different than what it needs to be. Can anyone suggest to me what has to be done for such type of problem?
June 27, 2022 at 12:53 pm
Ansys EmployeeYou need Mesh Motion, you don't want both in this case. Make sure the blades are set relative to the wheel volume.
3648
2534
1745
1226
578
