February 8, 2022 at 5:09 pm
dharmatejap
SubscriberHi,
Can you please provide syntax for running simulations on Linux without GUI?
February 8, 2022 at 11:22 pmLito Yap
Ansys EmployeeFebruary 8, 2022 at 11:27 pmdharmatejap
SubscriberI actually followed it.
My command is as follows
In the lumerical directory ./interconnect -hide -run fullpath.lsf -use-solve fullpath.icp
fullpath corresponds to the path of lsf and icp files
This still shows error corresponding to GUI license.
-use-solve is supposed to use the solver license according to the support page.
February 8, 2022 at 11:36 pmLito Yap
Ansys EmployeeNotes: Running the script.lsf from the terminal will always require a GUI/graphical connection to the Linux machine. The -hide option only hides the display from appearing -- it will still require a GUI/graphical connection to the Linux machine (i.e VNC or Xforwarding). The -use-solve option will require additional solve license = 2 lum_interconnect_solve licenses will be checked out. Try:
February 8, 2022 at 11:38 pmdharmatejap
SubscriberI have additional solve license but only 1 GUI license.
Is there any way to run interconnect without using GUI license?
February 9, 2022 at 4:06 amLito Yap
Ansys EmployeeSorry, the -use-solve feature is currently supported on FDTD not INTERCONNECT.
Viewing 5 reply threads- You must be logged in to reply to this topic.
- Error on Lumerical device
3850
2607
1853
1246
600
