May 4, 2022 at 6:34 pm
zdfrankman
SubscriberI am modeling a 5mm by 1mm by 50mm channel filled with fluid under laminar flow with a 2400Pa pressure differential. Analytically, it should produce a maximum velocity of 6m/s. However, ANSYS Fluent produces a maximum velocity of ~2m/s with the same inputs.
I am unsure why, but my velocity is only one third of the predicted velocity from Poiseuille equation for a rectangular channel.
All input parameters (viscosity, pressure differential, channel height, etc) are the same. Therefore I hypothesize that the disparity in result magnitude originates from an improper meshing or simulation setup.
What did I do wrong, and how can I use ANSYS fluent to provide more analytically accurate solutions?
May 5, 2022 at 7:20 amDrAmine
Ansys EmployeeAnalytical Solution is assuming a fully developed flow. For laminar flow for example you require at least 100D.l Moreover for duct the velocity profile will be bit different. Please try to make your near wall mesh better and assess a uniform mesh along the streamwise direction!
Viewing 1 reply thread- The topic ‘Simulation results different from Analytical solution’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
