February 15, 2023 at 2:55 pm
marufhossain
SubscriberI have completed a simulation in HFSS, and the results are in the aedtresults. But I cannot see them in the HFSS project file. The Solution Data button is grayed out, however, I can see in the 'Browse Solutions' that the solutions are still valid. How can I import the results back to the project?
AEDT Version 2022R1. -
March 2, 2023 at 5:26 pm
Praneeth
Ansys EmployeeHi Marufhossain,
Thank you for reaching out and your patience is much appreciated.
Is it the same case if you rerun the simulation?
Usually, if the simulation results are stored, your simulation will be complete in less time after rerunning it. And if that is not the case, it will take the normal simulation required for that model.
Did you do any modifications to the simulation model after a successful simulation? Then this might happen. Please share the screenshot of the items under the results category in the project manager window.
Best regards,
Praneeth.
- Maxwell, HFSS or Q3D?
- Error
3930
2649
1861
1272
610
