March 7, 2021 at 12:55 am
Kyle
Ansys EmployeeNote: This post was copied over from the Lumerical Knowledge Exchange.
The objective of this section is to explain the importance of simulation time for frequency domain monitors. If simulations are not run long enough for the electromagnetic fields to decay, the frequency domain monitor data may not be accurate.
Viewing 0 reply threads- You must be logged in to reply to this topic.
- Error on Lumerical device
2656
2120
1349
1118
461
