December 15, 2022 at 4:42 pm
rakesh_krishna
SubscriberI am trying to observe the spectral response of a single ring resonator element in the interconnect. Ideally I expect a spectral response showing peaks with an FSR. The layout is shown in the attached image below. But the ONA does not show any results. The warning includes a deadlock connection for the waveguide and an error that no value for gain can be found in the ONA. Is there a wrong connection here leading to such an error?
December 16, 2022 at 12:00 am
Guanhui Wang
Ansys EmployeeHi rakesh_krishna,
The problem is that the single bus ring is a unidirectional element which means that the signal can only go from the input to the output. Wiht that definition, the way you connect the ONA is wrong. You may want to flip the ring model, or use a bi-directional ring model.
December 16, 2022 at 1:43 am
rakesh_krishna
SubscriberThanks Guanhui. I replaced the ring model with a bidirectional element. However, no peaks seem to be detected in the ONA. I changed the frequency range parameter in the ONA, but still couldn't find any peaks. Does it have to do with the coupling coefficient/length of the ring? I kept the length as 188.4 um which is the circumference of a ring with 30 um radius.
- Error on Lumerical device
2616
2098
1323
1110
461
