March 23, 2021 at 8:42 am
Lukas8778
SubscriberHey, nI'm trying to excite my PMSM motor phases with a sinusoidal current equation but I'm not sure how to define the equation with according time dependent variables.nI want to have an Amplitude of 750A at a 33 Hz frequency (105.9 rpm at 500V). nCan anyone help me how to define the equations for each phase?.Kind regardsnnLukasn -
March 23, 2021 at 10:45 am
March 23, 2021 at 6:46 pm
icellb1
Ansys EmployeeHi, nYou can compare all your setups with build-in examples in Maxwell to troubleshoot: nClick file on the top left corner, choose Open examples, then click RMxprt. Choose the motor type of interest, e.g. pmsg. Open the design. nThen run the design. After completing analysis, right click on Analyze-->Create Maxwell Design-->ok. A ready-to-run maxwell design will be automatically generated. You can check if there's any difference between your setups and its. n -
March 24, 2021 at 12:24 pm
Lukas8778
SubscriberHey, nThank you for your answer, I'm aware of the examples but couldn't find any solution yet.nMy simulation works fine with voltage excitation but somehow not with a current excitation.nIs the equation I use correct? What else has to be set in order to excite with constant sinusoidal current?nThank you for your help n -
March 31, 2021 at 6:15 pm
icellb1
Ansys EmployeeHi,nYour equation looks correct. Did you get 0 current in the current waveform when you use any current excitation or just the one you showed? For example, try a DC current and see if it's still 0.n
Viewing 4 reply threads
Trending discussions
- Maxwell, HFSS or Q3D?
- Error
Top Contributors
2600
2088
1317
1108
459
Top Rated Tags
