June 22, 2021 at 6:19 am
ranjanpal999
SubscriberHi,
I referred to an example of PMSM motor available in *ExamplesTwin BuilderComponentsInterfacesMaxwellTR-TR2D
June 29, 2021 at 12:19 pmHDLI
Ansys EmployeeJuly 5, 2021 at 2:54 amranjanpal999
SubscriberHello HDLI Thanks a lot for your feedback. I shall apply the same.
The reason to set the sinusoidal function for inductance is to create an environment for changing load torque.
In one of my earlier posts, you had clarified that mechanical transient process could not be performed on PMSM motors. (https://forum.ansys.com/discussion/27747/load-torque-vs-transient-torque-for-pmsm-motor-coupled-with-vfd#latest)
Now, please consider following 2 points:
Inductance tend to change with change in current (https://www.researchgate.net/post/Does_the_inductance_changes_with_current_change_in_a_magnetic_circuit_containing_inductor_coil_resistance)
And, change in current is also an indication for change in load torque.
So, combining points 1 and 2, it can be said that, if inductance is a assumed as a sinusoidal function then, current will also tend to vary, which means load is varying.
Please let me know your views on this.
August 19, 2021 at 6:03 pmApril 27, 2022 at 2:01 pmMeroz
Viewing 4 reply threads- The topic ‘Sinusoidal inductance in PMSM’ is closed to new replies.
Trending discussions- Applying rotor skew
- Effect of region on force calculation
- How to make the available GPU on my Desktop to be used for direct solver simulations in ANSYS HFSS ?
- Parasolid entity check failed for part
- HFSS Parasolid Error
- Induction Heating Simulation
- Co-simulation between HFSS and structural/workbench
- IBIS AMI models
- Radial and Tangential force
- example files
8808
4658
3153
1680
1470
