Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
SIwave does not generate .bin files while simulating SYZ parameters
    • Marin Milovac
      I have an issue with SIwave while simulating SYZ parameters of any circuit. The simulation finishes normally, but when I try to open the simulation results I find the following message:
      When I try to find that file, I find out that the software did not generate that file:
      Also, one more thing when I try to save the simulation I get the following message:
      Previously simulation was running normally, but for some reason now it is outputting this error. If someone knows what is going on I would be very grateful.
      Marin
    • Dan Dv
      That appears to be due to an internmittant bug that was in the initial release of SIwave 2023R1. Please update to the latest patch to that release or to the latest 2023R2 and that should resolve the issue.
    • Marin Milovac
      Is there any way to patch ansys from AED or SIwave or do I need to contact the distributor to give me another version?
      Thank you,
      Marin
      • Dan Dv
        Hello Marin,
        No, you cannot obtain a patch or new version from inside of SIwave itself. If you don't have direct access to the Ansys Customer Portal, then you will need to reach out the distributor who provided you the initial installation files to get the patch or new version.
        Best regards,
        -Dan
