size optimization
    • HossamMedhat
      I always get this error while trying to update the Design points doing Response Surface Optimization. if anyone can help.
    • peteroznewman
      I suggest you follow the instructions given in the error.
    • HossamMedhat
      I already did that and nothing changed.
    • peteroznewman
      So show me what the error looks like for that Design Point in Mechanical.
    • HossamMedhat
      The error doesn't appear in Mechanical, it appears while updating the Model for the Design Point assigned.
    • peteroznewman
      Open Mechanical at that design point set of parameter values.
      Click Solve. What is the error that the solver returns?
      That error is the root cause of the error that you are asking about.  One error generates the next. Do you understand?
Viewing 5 reply threads
