January 23, 2019 at 9:41 pm
January 23, 2019 at 10:00 pm
Divya Shree Surendran
Ansys EmployeeHello
It seems you are using 4K resolution display. ANSYS applications do not scale well on 4K resolution yet.
You can try this workaround:
A workaround that others report as working fine is to reduce the resolution (try 1920 x 1080) and then also adjust your windows scaling settings, reduce the scaling to 100%.
Reboot/log out and log in after making the resolution changes.
Also try on the ANSYS Product (Workbench in this case) shortcut and select Properties. Under Compatibility select "Disable display scaling on high DPI settings".
Thanks,
Divya
August 17, 2020 at 3:42 pm
December 2, 2022 at 10:33 am
bhagwantP
Ansys EmployeeSteps to fix this are explained in this video too:
https://www.youtube.com/watch?v=Kwa62aE3rro
Chapter 1: ANSYS with overlapped tab and small font size issue - YouTube
June 1, 2023 at 7:31 am
Jan Janikovic
SubscriberSuggestion from @labyrinth01 does the job. The issue however still persists, if e.g. DESIGN MODELER is opened from WORKBENCH. Even if file properties of AnsysWBU.exe (which is the file for the DESIGN MODELER) are changed in the same way, the DPI scaling issues persist.
June 16, 2023 at 2:44 pm
- The topic ‘Sizing on Ansys Workbench 19.2’ is closed to new replies.
- Licensing – Request name does not exist in the licensing pool
- 2022 R1 Ansys Mechanical APDL: QXcbConnection: Failed to initialize XRandr
- error “ansyslmd: Cannot connect to license server system. (-15,10032)
- The analysis systems in Workbench are missing
- Student license renewal
- Mechanical APDL Launcher Options
- how to open files created from newer version by using the older version of ansys
- Problems using 2022/R2
- Results Probe in ANSYS Workbench
- Unable to delete system in Ansys Workbench
8808
4658
3153
1680
1470
