March 19, 2021 at 6:44 am
Manichayan13
SubscriberThe Create Pattern option for the move tool does not offer the three fields for entering the spacing between the created patterns just the Count option on SpaceClaim. I do get a warning when i try to do this :Not all constraints or dimensions may have been able to be preserved. nI am on Ansys 2020R2 Student version.nThank you.n -
March 19, 2021 at 10:07 am
Keyur Kanade
Ansys EmployeeYes, it is for 2D. nPlease use pattern option in 3D. nPlease go through help manual for more details nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn -
March 20, 2021 at 5:44 am
Manichayan13
SubscriberDo you happen to know if they fixed it in the 2021R1 release?n
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2706
2146
1357
1144
462
