November 13, 2018 at 8:10 am
abd fs
SubscriberDear all,
I have been modeling turbulent flow around a ramp 25° with a model model k-omeaga SST. I got y+<1 ,The Xr indicates the reattach length and for this case we get a Xr/h value equal Xr/h = 6.5. According with the experimental data the mean value of rettach length is Xr/h = 6,2and my velocity profile is:
how can I lose the value of Xr to get 6.2 ?
November 13, 2018 at 8:27 am
DrAmine
Ansys EmployeeFirs of all 6.5 to 6.2 is not really bad (less than 5%). Think about using some other turbulence model (what are you using here) and mesh sensitivity study and summarize the work. 100% concordance is almost not feasible.
November 13, 2018 at 8:34 am
abd fs
Subscribersorry Sir Amine but I got 7.5 not 6.5 just typo.
Best regards,
SERARE
November 13, 2018 at 10:38 am
seeta gunti
Ansys EmployeeTry with realizable k-e with enhanced wall treatment. You may get much closer result. RKE model is more suitable for shear flows involving rapid strain, moderate swirl, boundary layer separation and vortex shedding behind the bluff bodies etc.
Seeta.
November 13, 2018 at 10:44 am
DrAmine
Ansys EmployeeInflow quantities are very crucial here: Please check what has been set in the experiments!
November 13, 2018 at 10:48 am
abd fs
SubscriberThank you seeta gunti,
I have to use k-w SST to validate the results obtained with the same model and the same conditions
Best regrads,
SERRARE
November 13, 2018 at 12:35 pm
abd fs
SubscriberDear all,
in case I inject a velocity at the entrance Uref = 15m / s, I obtained an aerodynamic coefficient but the velocity profile at an abscise reference x = -8,9h is not correct in the opposite case if I inject a thoroughly developed turbulent velocity profile extracted from a tube I got a large recirculation zone with an Xr = 7.5h and the velocity profile at the reference point and just
Someone can help me? With some tips, comments?
Best regrads,
SERRARE
November 13, 2018 at 2:28 pm
DrAmine
Ansys EmployeePlease be more precise and provide some information about the paper and experiments. You need to match the conditions in the experiments.
How did you generate the profiles? What are using in the running case only velocity or other properties?
November 13, 2018 at 5:49 pm
DrAmine
Ansys Employee1/Please generate fully developed profile by assuming periodicity for your tube.
2/Actually almost all turbulence models obeying a simple formalism like the Boussinessq approach will predict good results whenever the flow is fully developed. Enhancement can be done through some advanced models or by changing the formalism.
3/Form the experiment it is said 15 m/s but perhaps they are talking about the bulk and not providing any information about the inflow regions (disturbances, fluctuations). As someone who has done some experiments, I have seen runs done without flow straightener...without mentioning that in papers and books.
4/SST model is fine. Same applies for Realizable with EWT or Menter et. al.
5/Summarize all work and write your report: All results are good to be reported if they are well documented.
November 13, 2018 at 7:26 pm
November 13, 2018 at 7:37 pm
DrAmine
Ansys Employee1/Read tube case
2/if your inlet and outlet are matching then go in the console and type mesh/modify-zones/make-periodic text command give the ids of inlet and outlet and say no. Now in GUI under periodic conditions provide the mass flow rate.
2/Change inlet and outlet to interface and crate mesh interface + periodic in the case you do not have conformal matching boundaries.
Check 5.9.4. Creating Conformal Periodic Zones in User's guide and have fun!
November 13, 2018 at 7:42 pm
abd fs
SubscriberThank you so mush Sir AMINE
I will try this and post here the results
Best regards,
SERRARE
November 13, 2018 at 10:49 pm
Karthik R
AdministratorHello,
Here are some links which might help you understand Amine's suggestions better.
These posts contain elaborate discussion on a problem similar to yours. I hope these help you understand the model better.
Thank you.
Best Regards,
Karthik
November 13, 2018 at 11:00 pm
abd fs
SubscriberThank you so much Sir Kremella
2620
2098
1327
1110
461
