September 9, 2023 at 4:17 am
Aras karimi
SubscriberHi everyone, I want to loft the following two airfoils together. At first, the skin/loft command gave me an error as shown below: To solve this problem, I used the split edge tool to divide both airfoils into two equal parts, and this time the skin command managed to loft them, as shown below: Next, I drew a domain around it and subtracted the geometry of the wing from it, which is as shown in the following figure: I went to the ICEM software to mesh it, But the problem is that a quarter of the front face of the domain is missing.as shown in the figure below: (The brown color is the selected page)Can anyone help me to solve this problem?
Thanks in advance.
September 11, 2023 at 5:42 am
Keyur Kanade
Ansys EmployeeCan you please check if you can use Ansys Meshing? Any particular reason you are using ICEMCFD?
Please check following videos
Ansys Meshing Sizing:
https://www.youtube.com/watch?v=w4q6q8nKF3UAnsys Meshing: Decomposition for hex meshing:
https://www.youtube.com/watch?v=P19GOTQWmc0Ansys Meshing: Meshing Methods:
https://www.youtube.com/watch?v=nEOC8rDnnRoAnsys Meshing: Inflation:
https://www.youtube.com/watch?v=lrEHXizrhC0Regards,
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7626
4456
2955
1427
1322
