October 4, 2018 at 5:04 pm
eman
Subscriberhow i can edit the skull dimension on ansys (explicit dynamic)
such that the fille is imported not made in ansys
October 4, 2018 at 5:27 pm
Sandeep Medikonda
Ansys EmployeeDo you have a CAD geometry? You can always use SpaceClaim and DesignModeler to edit and export geometries? You have many CAD neutral options, when you do File>Save As
If you want to export the results, you can just right click on the result and export as shown:
Sandeep
Best Practices to post on the Student Community -
October 4, 2018 at 6:57 pm
Sandeep Medikonda
Ansys Employeeeman,
You can edit an IGES geometry in SpaceClaim just like any other using the Edit tools. Below, I show this for a simple cube using the Pull tool.
Sandeep
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2066
1279
1096
457
