January 24, 2023 at 9:46 am
January 24, 2023 at 1:38 pm
SaiD
Ansys EmployeeHello,
Could you explain what exactly you mean by a "sliding pivot" link? It seems to be similar to a cylindrical joint. In a cylindrical joint between 1 and 2, assuming z-direction is normal to the screen, 1 can rotate about z-axis and translate along z-axis, with respect to 2 (assuming 2 is fixed). Is this the behavior you want to simulate?
If yes, then you can set up "Cylindrical Joint" Connection between the respective parts. In Ansys Help for Mechanical, you can find this information under Setting Connections > Joints > Joint Types > Cylindrical Joint.
Hope this helps.
January 24, 2023 at 2:26 pm
Machin_waz
Subscriber -
January 24, 2023 at 4:11 pm
Could you elaborate your problem a bit more? What do you mean by "it does not allow me to run the calculation"? Does the simulation start and stop due to some error? Or does it not start at all?
In either case, you should be getting some error message.
In your image, I see a question mark next to "Static Structural", so I suspect some value/condition that is required to start the simulation is not defined. Could you expand each of the folders under "Static Structural" and see if there's a question mark next to it? Also check the details of Analysis Settings. Any required value that is missing should be highlighted in yellow in the respective "Details" window.
January 24, 2023 at 4:33 pm
Machin_waz
Subscriber@Said,
the problem was that I was using cyclic symmetry. This one is not compatible with the joints
2066
1279
1096
457
