Sliding with friction. How can i solve this issue?
    • francescone96
      Hi everybody
      I try to make an overview of the problem:
    • peteroznewman
      nFor a solid element, a Fixed Support is the same as a Displacement with X, Y, and Z = 0. It is simpler in a multistep analysis to change a Displacement from 0 to non-zero between steps. You can also use two Displacement BC, one with Y and Z = 0 and another with X = 0. In that way you can changes just the X value between steps.n
    • francescone96
      i'll try that. nI tried to block all the directions with a single displacement BC, but the simulation stopped after the launch. The use of two displacement it's working right now. Hope i get the results. nAnyway thank you a lot for the fast reply and for the suggestion! n
