Photonics
Photonics
Slot waveguide_MODE
    • Alisa Bannaron
      I have been trying to create a strip-loaded slot waveguide and sun the modal analysis.However, I encountered this problem that the mode is not confined in mode1 in Eigensolver analysis
      I couldnot find an example files for slot waveguide and I`m pretty new to the software, could you please suggest how should I fix or any other way to create better simulation object?
      Thanks in advance
      Also, could you suggest on how can I run parameter sweep for slot width and rail width?
      Sincerely yours,
      Alisa
    • Alisa Bannaron
    • Guilin Sun
      You may first try to find the modes in one waveguide, and see if they expected. then check the slot modes. You may need to sweep the gap to find the better confined slot modes.
