TAGGED: ansys-mechanical, cfd, fluent, fluid-dynamics, fluid-flow
May 18, 2022 at 1:20 am
MechEngStud
Subscriberwhy is it the Power Coefficient (Cp) of slotted airfoil wind turbine blade has a higher value at low tsr compare to a normal wind turbine blade? But as the tsr increases the Cp of slotted airfoil blade decreases so much compare to a normal wind turbine blade?
May 18, 2022 at 5:19 amViewing 1 reply thread- The topic ‘Slotted airfoil wind turbine blade’ is closed to new replies.
Trending discussions- Floating point exception in Fluent
- Using GPU in FLUENT
8808
4658
3151
1680
1470
