TAGGED: ansys-mechanical, fluent, fluid-flow, fluids, mechanical
May 18, 2022 at 1:21 am
MechEngStud
Subscriberwhy is it the Power Coefficient (Cp) of slotted airfoil wind turbine blade has a higher value at low tsr compare to a normal wind turbine blade? But as the tsr increases the Cp of slotted airfoil blade decreases so much compare to a normal wind turbine blade?
May 18, 2022 at 12:31 pmRob
Forum ModeratorWhat does the literature say on the matter? Have you modelled both?
May 19, 2022 at 1:19 amMechEngStud
Subscriberyes i modelled both. the slotted airfoil wind turbine has a higher Cp at low tsr compare to the baseline blade. but as the tsr increases the Cp of the slotted airfoil wind turbine blade has a lower Cp compare to the baseline blade.
May 19, 2022 at 8:59 amRob
Forum ModeratorOK, assuming you've taken area etc into account for the coefficient what does literature say about the benefits (or otherwise) of slotted blades?
May 20, 2022 at 4:57 amMechEngStud
SubscriberIt delays the separations of fluid at the tail end of the airfoil becoz the slot re energize the streanlime delaying the drag. in low tsr, the slot is effective but in high tsr the slot is a disadvantage as it decreases the value of Cp. my question is why is this phenomenom happening? care to explain?
May 20, 2022 at 10:20 amRob
Forum ModeratorIt'll be linked to boundary layer separation and turbulence. That's one for the Courses, or a text book.
Viewing 5 reply threads- The topic ‘SLotted airfoil wind turbine blade’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3155
1688
1478
