Slow at iteration 1 and then diverges
    • atulsingh92
      Hello ,
      So, I wanted to know if there would be any general reasons to fix if my 1st 10-15 iterations take a lot of time to come, and then my simulation diverges at 100-200 iterations later. The ones from lets say 30 to 100 are quick enough on a 6 core pc with 300k cells (small size), although it diverges anyways.
      The question is why would iterations 1 to 10 take so much time, compared to others, where ideally, the solver runs quickly.
      I have mass-flow-inlet at the blue region, attached to the 4 tubes and a symmetric design at the other end.
    • DrAmine
      First of all check if the mesh of proper quality in Fluent: Orthogonal quality, Skewness as well as aspect ratio
    • atulsingh92
      Min orthognal quality comes at around 0.2
      And I think it should be less than 0.1
      But as I am using the "outline tab" for meshing in fluent meshing using batch submission with the help of TUI commands (2019R2), I am unsure of how can I get this under 0.1 ?
      Any suggestions?
    • DrAmine
      Orth quality should be as large as possible: values near 1 are ideal (1 will imply pure hex). So no need to try to reduce it...
      Did you define "zero temperature" or leave it as the default condition? What is the inlet velocity?
    • atulsingh92
      Yes, the rectangular region is a wall with zero temperature, while the tubes are at 300k, with fluid at 373K. The blue area is mass flow inlet at 0.0014 kg/s. The whole domain should have the bounding box of (700 X 100 X 40 )mm.
      You set zero temperature? Which units are you using?
    • atulsingh92
      With energy on, I have set thermal BC-> Temperature-zero to the recatangular region as follows
      However, I have also tried with the heat-flux as zero for the same case, where it diverged!
      Units are SI
Viewing 7 reply threads
