October 24, 2023 at 12:16 pm
GUICAD
SubscriberHello,
Our customer is experiencing slow print previews.
Have you encountered this problem before?
It's ok from another workstation with the same printer.
This one is connected to the networkp.s : is it possible to share video to the forum
Thanks,
October 25, 2023 at 5:45 am
Charudatta Bandgar
Forum ModeratorIs this a file specific issue, or you are facing this for all the files? I think it being not saved on locally could be the reason for it, but see if you face the issue with all the files, or this particular one, we can get an idea from that.
Regards.
October 25, 2023 at 9:32 am
GUICAD
SubscriberIt happens with every file. Even a simple new document
- pcb
- No longer possible to import f3d with 2023?
- line bodies and surface body shared topology
- How to chang unit in Ansys Discovery 2023?
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- SpaceClaim Script: Selection by FilterByBoundingBox
- Assignment of revolute joint
- Max/min over time results in AIM
- Axisymmetric model – Rubber seal
- To change language in Ansys Discovery
8808
4658
3151
1680
1470
