January 13, 2023 at 8:05 am
dfsdf dfsdf
SubscriberHello,I'm trying to simulate SMA two-way memory effect with thermal effect. I've checked the Simulation of a Spinal Spacer Implant, but I found it seems to be a one way memory effect.
I wanna know how to simulate two-way memory effect with thermal effect in ANSYS.
Is it possible to perform a Shape Memory Alloy Shape Training in ANSYS.
Any advice will be appreaciated.😀
January 19, 2023 at 1:51 pm
John Doyle
Ansys EmployeeI assume by the '...Spinal Spacer Implant...', you are referring to Chapter 40 of the MAPDL Technology Showcase example.
Is there something specific about that documented workflow that is not working as expected for your application?
January 30, 2023 at 6:42 am
dfsdf dfsdf
Subscriber.
January 30, 2023 at 6:43 am
dfsdf dfsdf
SubscriberThanks for your reply.
You’re right and I am referring to Chapter 40 of the MAPDL Technology Showcase example.
The shape of the spinal spacer recovered because of heating in this example, but when the temperature decreases,the shape of the spinal spacer doesn’t change.
I wanna make the SMA recover its original shape when heated and turn back into the shape before heated when cooled.
- Invalid Assignment error
- How do I make a chart with multiple material parameters on y-axis?
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- ANSYS 19.0 with Additive Manufacturing Extension
- How to add SN curve for new material in Fatigue analysis?
- Looking for Spring steel (55Si7) library material
- properties of balsa wood
- Ansys material damage
2564
2074
1289
1106
459
