March 13, 2021 at 12:07 pm
TryingMyBest1232
SubscriberHello,
I am relatively new to ANSYS Fluent so forgive me if I have made any stupid mistakes.
I am trying to model a solar cyclone tower (SCT). This is identical to a solar updraft tower (SUT) except for the addition of swirl vanes to generate a cyclone. An SUT collects the sun's energy in a solar collector and heats air. This hot air rises through a central tower and can be used to turn turbines.
I started by modelling the SUT to make sure that my setup was correct. With many previous studies available, I was able to predict the maximum updraft velocity to be 56.7m/s. The simulation value fell only a couple of meters per second away from this, leaving me confident that everything was working as expected.
I moved on to testing the SCT. The setup was left exactly the same (duplicated) and the only change in the geometry was the addition of swirl vanes. Now fluent does not converge and the answer is all over the place. Every iteration has cells limited to T=5e3k and cells limited to T=1e0k. The velocities in the 'solution' are 6 times larger than the SUT, even though they should be fairly similar.
Since both simulations have the same setup, I came to conclusion that the mesh must be the problem. So I tried everything I could to improve it. My experience is limited, but I found a lot of things I tried didn't help or made things worse. The mesh parameters seem reasonable, so I'm not sure if this is responsible or if it's something else.
I would really appreciate some help on this, I've been stuck on it for over a week. I have attached images of the mesh as well as mesh parameters. I have also attached wbpz files for the SCT and SUT.
Setup:
Steady-state calculation.
Heat is applied with solar race tracing and the DO radiation model
inlet - pressure inlet 0Pa , 293k
outlet - pressure outlet 0Pa, 293k
glass collector - semi-transparent to solar rays. Thermal = mixed (coef = 10, temps = 293k)
ground in collector - absorbs solar rays. Thermal = convection (coef = 10, temp = 293k)
operating temperature - 293k
operating density - 1.2 kg/m3
viscosity - RNG k-epsilon
coupling - SIMPLE
gradient - Green-Gauss cell based
pressure - PRESTO!
All other methods - second order upwind
Element Quality:
March 13, 2021 at 12:08 pmTryingMyBest1232
SubscriberThe mesh shown here was generated with a multi zone sweep and inflation layers on the swirl vanes and tower. nMarch 13, 2021 at 1:30 pmYasserSelima
SubscriberTry using Pseudo transient ... change all settings to first order until you get convergence, then set it back to higher ordernnIf you still can't get convergence, try running unsteady simulation nViewing 2 reply threads- You must be logged in to reply to this topic.
2564
2078
1293
1106
459
