August 15, 2023 at 6:18 pm
rajatkumar.sinha
SubscriberWhen zbf file (with lumerical FDTD data) is imported into POP module on zemax optic studio - should the focusing of the metalens occur directly taking the object as the data from FDTD or should a separate lens be defined to take in the metalens data for focusing at a particular distance ?
And can FWHM in subwavelength be achieved on zemax opticstudio? If yes, what are the settings on the software through which we can reduce the fwhm? -
August 15, 2023 at 9:39 pm
Guilin Sun
Ansys EmployeeSince this is a Zemax question, it is better to post in Zemax community:
https://community.zemax.com/
I found some information here
https://support.zemax.com/hc/en-us/articles/1500005491181-How-to-design-DOE-lens-or-metalens-in-OpticStudio
Since usually the metalens is designed with a plane wave illumination, so when it is the first element in the optical system, the imported FDTD result as the source has the information of phase (and thus the wavefront). with the help of POP, it propagates to the conventional lens so the rest is easy.
If the metalens is not illiminated with plane wave (such as it is inside the optical system), things can be complecated. This is because it can be a challenge to design the metalens with proper phase profile required, since the elementary composites (eg, rectangles, cyilinders or rods) might not be simulated with periodic boundary conditions, due to the fact that the illumination is not a plane wave. It might work but will need special considerations. If this is the case please try to find some references and see how others do it.
- Error on Lumerical device
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Lumerical – error message when trying to open from Linux terminal
7592
4440
2953
1427
1322
