December 14, 2020 at 1:48 pm
nw196
SubscriberHi,I'm running a fatigue cycle on a hollow cylinder of shell thickness 40mm, with a Semi Elliptical Crack on the surface. nMy SMART crack model runs up to a crack extension of 24mm after a cycle of ~77000 cycles, at which point the model stops. nHas it stopped at 24mm as the software believes this is the critical crack length? or because it's met some other parameter? nI have not set a predetermined crack length or time for the model to stop.Any help appreciated.n -
December 15, 2020 at 1:27 pm
Ashish Khemka
Forum ModeratornFor the SMART crack model do you have the Auto Time Stepping set to Program Controlled?nSMART crack growth will only calculate the first result in that case because the solver will default to one substep. For calculating more increments you need to specify more substeps. For instance, set Auto Time Stepping to 'Off' and then specify the number of substeps.nRegards,nAshish Khemkann
- The topic ‘SMART crack growth – critical crack length’ is closed to new replies.
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3153
1680
1470
