November 20, 2018 at 2:59 am
dlee0041
SubscriberPlease help with this error message
*** ERROR *** CP = 43.484 TIME= 20:47:26
For Cgrow Id 1 and Crack Id 1, the computed number of cycles is less
than 1. Please check your model and fatigue parameters. The crack
growth solve is aborted.
TOTAL ACCUMULATED MAX CRACK EXTENSION INC 0.0000
November 20, 2018 at 3:10 am
Sandeep Medikonda
Ansys EmployeePlease elaborate with details of your model, materials and how you are setting this up (include inline pictures).
I would strongly recommend you do go over the tutorials first so that you can eliminate any mistakes in methodology/implementation.
November 20, 2018 at 7:14 pm
dlee0041
I am running Analysis on a specimen that has a rivet hole in the center and a small notch that Is cut into the right of the hole where the crack is suppose to start and propagate the material is Aluminum 7075-t6 .force is applied to the
top and bottom faces of 5000N. I am basing this Analysis from experimentation. In the experiment the forces were applied over 30000 or so cycle and the crack length was monitored. I am trying to simulate this fatigue test in ANSYS. I also do not know if I am inputting the number of cycles that I need ran correctly. I turned on the weak springs feature to give the structure some type of constraints.
November 20, 2018 at 8:54 pm
David Weed
Ansys EmployeeHi,
The message indicates that due to either 1) the magnitude of the applied load or 2) the Paris' Law constants, the analysis produces a solution that is not fatigue-driven (where crack growth evolution occurs over a large number of cycles), but rather sudden crack growth is occurring. Looking at your Paris' Law constants, I would check the literature or other sources to make sure that these are appropriate. Typically, for the material you're using, C is reported as being much smaller.
November 21, 2018 at 1:55 am
dlee0041
SubscriberNow using a C value of
2.5 e-9
And 6.85 e-8
But still receiving the same error messages -
November 27, 2018 at 1:49 am
dlee0041
Subscribernow receiving this error message
An unexpected error ( SIG$SEGV ) has occurred... ANSYS internal data
has been corrupted. ANSYS is unable to recover and will terminate.
Previously saved files are unaffected. Please send the data leading
to this operation to your technical support provider, as this will
allow ANSYS, Inc to improve the program.
I edited my engineering data and change my unit for the paris law constants but now a new error. What should I do?
November 28, 2018 at 6:20 pm
David Weed
Ansys EmployeeHi,
Are you able to run your model in the latest release (R19.2)? There may be a defect present in R19.0 which has since been fixed in a future release.
2066
1279
1096
457
