Discovery Import
Discovery Import
Smart Fluids – Imported vs Existing Body Conditions
    • z5115177
      When I attach conditions (e.g. temp) to a body that was in existence when the solution was first generated and I move that body from point A to B the conditions continue to exist at point A. When the same body is imported, after the initial solution is generated, and moved to from A to B the conditions attached to that body move.
      Is this behavior expected?
      Thank you in advance
    • Naresh Patre
      Hello cos1997 I was unable to reproduce the issue you mentioned. Upon moving the body (assigned temperature = 40 deg) to new location, the temperature results were updated based on new position. Refer below snapshots which shows the temperature results at 2 positions.   Was the fluid volume created within Discovery Live or it was imported along with the solid? Can you send a test case for further investigation?
    • z5115177
      Hi Naresh Patre Yes the fluid volume was created in Discovery Live. Please find the attached case, the body of interest to move is named "STOVE".
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      • Naresh Patre
        cos1997 I am unable to open the full model as it is looking for one file named "v2.2.scdoc". Can you please upload this file as well?
    • z5115177
      Apologies, see file attached. Does discovery have an archive function similar to that of workbench?
      • Naresh Patre
        cos1997 The model has external components referenced and current version of Discovery Live does not support external references.
        As a workaround, if I box select all the bodies (25) in graphics window and move them to a new location, the results get updated.
Viewing 3 reply threads
