Smoothed VOF gradient
    • prebenjs
      What does the Smoothed VOF gradient really show. I read the the guides but couldn't really get a good grasp of what it really is. Is it a good measure on interfacial diffusion between phases ?
    • KR
      Administrator
    • prebenjs
      I've read this, but as mentioned It would be nice with some more explanation about what this really measures, in a more "practical" way.
    • aitor.amatriain
      The smoothing process is based on the volumetric average over the cell neighbors
      43.14.2. Patch Dialog Box (ansys.com)
      It is essentially a simple filter.
    • prebenjs
      Yes, but what does the quantity of the smoothed VOF gradient really tell you ? Is this a measure that can be related to the interfacial diffusion between phases ?
    • aitor.amatriain
      I guess that it could be useful for post-processing in the case of coarse meshes.
      The phase continuity equation does not have any diffusion term, so all values that are not 0 or 1 are essentially caused by numerical diffusion.
    • prebenjs
      Maybe. But the meaning of the term Smoothed VOF gradient, do you have any easy explanation here. I guess one can say that it could be seen as a blending of volume fraction due to discontinuities or to allow mass balance in steep gradient areas, where blending is used as a tool to avoid discontinuities in the numerical values.
      Do you agree with this representation of the smoothed vof gradient ?
    • DrAmine
      Quantity used for curvature calculation and surface tension force.
    • DrAmine
      And one can use it or smooth vof field to add some smoothness when dealing with phase change which relies on interfacial area.
    • prebenjs
      Okay, So generally it will say something about the numerical diffusion between the phases caused by surface tension forces ? I don't get what you mean by your last comment.
    • prebenjs
Viewing 10 reply threads
  • The topic ‘Smoothed VOF gradient’ is closed to new replies.
