Preprocessing
Preprocessing
Smoothing transition from quadrilateral elements to triangular elements
    • AndreasLyng11
      Hello All
      I have meshed a 3D model of a butt weld via. submerged arc welding. The mesh were generated by sweeping the square volumes with quadrilateral elements and using triangular elements in the weld. I want to refine/smoothen the transition between quadrilateral elements and triangular elements. The mesh are seen below together with the areas where refinement is needed (marked with red)
    • Keyur Kanade
      As ANSYS Staff, we can not download attachments. Please insert images using insert image functionality.
      you will need to increase size of tet elements or reduce size of hex elements.
      please see help manual on definining sizing.
      also check following for sizing.
      Keyur
    • AndreasLyng11
      Thank you very much!
