TAGGED: convergence, peteroznewman, sandeepmedikonda, snap-fit
April 3, 2023 at 9:04 am
Sundar_Ram
SubscriberHi All,
I am having a snap problem using Hex elements. I am facing some initial penetration, its solving almost 50% and then I am facing element formulation error, I found out that this is due to the initial penetration of the model, I tried using Augmented lagrange with Stiffness factor as 10, Still i am getting some penetration, its stopping, Same thing I tried with Normal Lagrange as well. the result is the same. The image shown at the bottom is of normal lagrange. Any idea how to solve this. I am getting convergence in tet mesh. I wanted to try with Hex elements to reduce computational time. Also to avoid the difference of Stress distribution in unaveraged and averaged. Can anyone help?
April 3, 2023 at 10:10 am
Erik Kostson
Ansys EmployeeHi
There are many posts in the forum and online about this. E.g., one is:
https://www.youtube.com/watch?v=sZf5p_evqOk
All the best
Erik
April 3, 2023 at 12:56 pm
Akshay Maniyar
Ansys EmployeeHi @Sundar_Ram,
The video shared by Erik will be really helpful for you in setting the contact properly. Please go through it.
Also, you can try to use other detection methods (nodal detection method) and see if it helps.
Thank you,
Akshay Maniyar
3299
2469
