November 20, 2018 at 4:12 pm
Dwaipayan1234
SubscriberI am simulating core loss with soft magnetic composite (SMC) material in Ansys Maxwell. But while calculating core loss it should considered as electrical steel or power ferite. In Maxwell automatically it is automatically taking as a power ferite material? please suggest me. Thank you.
January 31, 2019 at 9:29 pm
mchristi
Ansys EmployeeIn Maxwell, soft magnetic composites are more similar to ferrites (as opposed to laminated electrical steel) for the purposes of core loss. Therefore, you can use the power ferrite Cm,X,Y core loss method.
- Maxwell, HFSS or Q3D?
- Error
2614
2088
1321
1108
459
