Ansys Products
Ansys Products
Software bug using Modeler >> Import
    • voyager
      When I attempt to import a file (e.g., .gds file) into my design, I encounter a software bug in the file selection window.
      I've attached two photos showing an example of this. When I select the file I would like to import, "test_file_to_demonstrate.gds" gets changed to "test_fil_to_demonsttrate.gds". Could this bug please be fixed?
      Thank you!
    • ANSYS_MMadore
      What version of which application are you importing into? Widows or Linux?n
    • voyager
      I am using Linux. ANSYS Electronic Desktop 2020 R1n
    • ANSYS_MMadore
      This is in fact a bug which has been reported to developers. For now the workaround is to manually modify the file name after selecting it to complete the import. This also occurs with 2021R1, so updating likely won't resolve the issue for you.nnThank you,nMattn
Viewing 3 reply threads
