March 9, 2023 at 7:38 am
Kamyab Karimi
Subscriberhi, when I am trying to define sph to sph coupling, LS-DYNA force exits (crashes).
may someone help me with this problem?
also, what type of contact should I select for cold spray (droplet and substrate are both sph)?
March 9, 2023 at 1:51 pm
Ram Gopisetti
Ansys EmployeeHi , try using the latest version of solver, R14, see the field CONT in *CONTROL_SPH
cheers, Ram
March 10, 2023 at 8:42 am
Kamyab Karimi
SubscriberI have student version of ls-dyna, and its up to date.
prepost ls-dyna force exits before evening simulation.
when I insert define_sph-sph-coupling card and click apply, the prepost program force exits.
without defining sph-sph coupling I get negative volume for particle error.
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
3812
2607
1853
1244
600
