January 24, 2023 at 1:46 am
orgenflow
SubscriberIm having issues opening the software I've tried re-installing from scratch and it keeps on closing ones i've put in my user name and password it just keeps on closing.
January 24, 2023 at 5:34 am
Atharv Joshi
Forum ModeratorHello Jgarcia ,
Can you please try activating the licenses using the command window and then try launching the application?
Please refer Discovery Subscription license - Command line options for instructions on activating licenses through command line.
Let me know if this resolves the issue.
Thanks and Regards
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7568
4424
2949
1414
1322
